What mods/power is needed to lift the front off?
Old Mar 29, 2003 | 08:05 PM
ProjectRS's Avatar
I am wondering, what are all the mods an LS1 M6 needs to
pop up the front at the track?
How much HP?
Thanks guys
Old Mar 29, 2003 | 08:13 PM
Ferocity02's Avatar
A lot
Old Mar 29, 2003 | 08:28 PM
ProjectRS's Avatar
really? Even like a few inches?
A guy here with an LT1 TA claims his 12 sec car (bolt ons) can
lift off in first gear (a4)
Old Mar 29, 2003 | 08:37 PM
stik6shift93's Avatar
Check out the issue of gmhtp with the lt1 bolt on shootout, there was a 13sec car that was lifting a wheel. With a manual trans its gonna take a lot more than an auto, reason being that the converters in the autos give the motor "torque multiplication" which essientally can double to triple the amount of torque the motor actually has on launch, m6s can do this.
Old Mar 29, 2003 | 10:07 PM
chpmnsws6's Avatar
could you just get coilovers and then jack the rear end all the way up, then launch like there is no tomorrow on slicks
just my thoughts,
mike
Old Mar 30, 2003 | 12:22 AM
My84Z's Avatar
12 bolt 4:10 or better full slicks nitrous and a big solid driveshaft you'll lift them off the ground. Why you would want to is beyond me cause it will slow you down and if you get high enough will do some serious damage to your car.
Old Mar 30, 2003 | 12:32 AM
StylezZ28's Avatar
HA go watch the super stocks baby. there is no better crowd pleaser then the super stocks pulling 2+ foot wheel stands and still running 10 seconds. Slow times? when u run 10's with a 2+ foot wheel stand let me know.
Old Mar 30, 2003 | 12:36 AM
jd13's Avatar
Wheelies are for the crowds, and while they are cool, do actually slow the car down compared to what it could run.
You want your momentum going forward, not up. This momentum lost to pulling the wheels UP should be converted to going straight ahead. Sure, you may not gain much, but there is some to be gained by keeping the wheels ON the ground.
Old Mar 30, 2003 | 12:47 AM
My84Z's Avatar
I believe jd13 answered my point
Old Mar 30, 2003 | 01:51 AM
stik6shift98's Avatar
remove the front sway bar...and get a 12 bolt with slicks....
its a lot harder for an m6 to wheelie then an a4.....
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
bossco
Nov 29, 2014 10:18 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
