Autocross and Road Racing Technique There is more to life than a straight line
BFG DR's on turns?
Old Mar 29, 2003 | 09:53 AM
cadjock's Avatar
BFG DR's on turns?
Has anybody tried going around corners (quickly) with BFG Drag Radials? I take my car to the drags and to the local round track for 1 on 1 drags. Will the DR help or hurt as compared to my other tires BFG Radial TA's ?
Old Apr 1, 2003 | 10:52 PM
ZDriver96's Avatar
5 of us in fbodys ( 3 ls1 camaros, 1 LS1 WS6, and my modded LT1) had to dodge a tire on a bridge last saturday. We were cruising 90mph.
I have bilstein HDs, 32mm front sway bar, sub frame connectors, and a pan hard rod. I run nitto drag radials on the back 275/40/17's.
Ive never whipped the car that hard at 90mph before. This was on concrete too, on a bridge that has more moisture than asphalt roads. Car held superbly and the nittos held just fine with no squeel.
The WS6 and 2 other LS1's were running nittos too. THe WS6 whipped his car the hardest and he made it out ok.. I thought he was going to lose it.
They have alittle more wiggle in them cuz of the softer side wall but will hold very well in a corner. Just not as well as my RE730's that i use to have.
If you dont auto x then the nittos will be fine for your handling needs
Boss002
May 20, 2015 12:55 PM
shroyvin56
Apr 19, 2015 09:40 PM
dpw21562
Jan 23, 2015 04:58 PM
formula79
26
Aug 5, 2002 12:21 PM
vic_wants_an_SS
Jul 30, 2002 11:38 AM
