Plugs mess up performance a lot?
Old Mar 29, 2003 | 03:24 AM
ollie-99's Avatar
Plugs mess up performance a lot???
i just did a cam swap and my car feels as if it should be better
i did not replace the plugs
thanks,
Oliver
Old Mar 29, 2003 | 03:37 AM
Wild1's Avatar
plugs are cheap... I'd change them out. Many go for the TR-55 by NGK. I went with the Bosch +4 plugs. Seem to be fine.
It is very easy to just tap the porcelin (white part) of the plug and get a microscopic crack! I did that to two of them... since you are up and it is dark outside... I'd pop the hood and start the car in a very dark spot. Peep your head around the engine and keeping all things away from any moving parts (belt). You may see faint blue sparks around your plugs... that is a sure indicator that they are cracked. Mine were on #4 and #8 but I never knew. Car idled ok...
During the day, I'd also check for vacuum leaks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
grabbem88
Mar 18, 2015 01:25 PM
Gtpguy
Jan 26, 2015 04:50 PM
bossco
Nov 29, 2014 10:18 AM
