tools for removing seats
Old 01-29-2004, 06:18 PM
billy-94z28's Avatar
Question tools for removing seats
Going to be removing the seats out of my z 28 for some new coverings and extra padding. Are there any special or oddball tool I will need to do this? Will I need some torx sockets - to remove torx head bolts. I have most "regular" sae and metric stuff.
Lets hear from those of you who have pulled seats.
Thanks for the responses.
billy-94z28 is offline
Old 01-29-2004, 07:12 PM
97FormulaWS-6's Avatar
If your talking just the seats, then all your going to need is a 13mm wrench or socket/wrachet, and a phillips screwdriver.. the Seatbelts require a T-47 torx.
I've had my interior stripped atleast 1/2 dozen times already...
97FormulaWS-6 is offline
Old 01-30-2004, 07:26 AM
that sounds good. i only have a few torx screwdrivers and need to purchase some additional tools torx bits etc. sometime.
thanks for the info.
Old 01-30-2004, 12:38 PM
94BlackBowtie's Avatar
Torx BITS are a must - not torx drivers - cause there's a few of those torx bolts you can't turn by hand - threaded with blue thread lock (Loc-Tite). The back seats require you to remove the seat belt bracket in order to get the backrest off as well - so you will HAVE to have them for that.
But yes - other than that like 97FormulaWS-6 said - a 13mm (I find deep wells useful for the rears where the studs seems to be longer) and a ratchet will do the trick.
94BlackBowtie is offline
Rod Bender
11-07-2023 02:30 PM
01-23-2015 01:13 PM
alphaauto
01-23-2015 07:42 AM
Timberwolf
07-30-2002 08:31 PM
Quick Reply: tools for removing seats
