replace 97 driver side door bezel
I found the two plastic pieces I need, but I do not want to break anything trying to replace the small keypad piece and the large piece that goes around the door handle. It looks like there are three screws that hold the larger piece in place. I do not need to replace the window switches or door lock switch. So can I replace the plastic without taking the switches out.
Just purchased the 97 SS t-tops and 6 speed with leather.
Re: replace 97 driver side door bezel
The switch panel pops in and out of the bezel just pop it out and you'll see the connectors underneath pull the switch panel from the connectors there's no clips so just pull and set aside then replace the bezel. When you put the new bezel in pull the connectors up and attach to the switch panel and pop it back in then you're done.
Hurin
12-13-2014 07:38 PM
