MBA pedal covers
Old 01-14-2004, 05:39 AM
Buffdaddy's Avatar
MBA pedal covers
Do these pedals snap over the stock pedals? I know some require drilling holes and I do not want to do that. Thanks.
Buffdaddy is offline
Old 01-14-2004, 02:34 PM
KillerTA's Avatar
I think you take the old ones off and screw the new ones in .
KillerTA is offline
Old 01-15-2004, 12:21 PM
P.Roz's Avatar
Brake and cluch (if you have) replace the stock rubber pads.
The gas pedal requires 2 small holes to be drilled.
The Dead Pedal/footrest also requires two holes to be drilled.
Hope this helps.
P.Roz is offline
Old 01-15-2004, 01:17 PM
KillerTA's Avatar
Re: MBA pedal covers
Maybe you could use some realy strong double sided tape for the gas pedal and the dead pedal.
KillerTA is offline
Old 01-15-2004, 08:06 PM
Buffdaddy's Avatar
How about if I epoxy the ones that need to be drilled?
Old 01-16-2004, 01:25 PM
KillerTA's Avatar
I'm assuming that you don't want to drill because you might want to take the pedals off at some point and return it to stock.
Epoxy won't be good because it might not come off the plastic and if you do manage to get it off, you'll probably ruin the plastics finish in the process.
KillerTA is offline
PROJECT X
04-17-2015 12:13 AM
CGM2010CAMARO
04-07-2015 07:44 PM
04-03-2015 10:54 AM
Red97LT1
9
12-17-2014 06:13 PM
Quick Reply: MBA pedal covers
