MBA pedal covers
Do these pedals snap over the stock pedals? I know some require drilling holes and I do not want to do that. Thanks.
I think you take the old ones off and screw the new ones in .
Brake and cluch (if you have) replace the stock rubber pads.
The gas pedal requires 2 small holes to be drilled. The Dead Pedal/footrest also requires two holes to be drilled. Hope this helps. |
Re: MBA pedal covers
Originally posted by Buffdaddy Do these pedals snap over the stock pedals? I know some require drilling holes and I do not want to do that. Thanks. |
How about if I epoxy the ones that need to be drilled?
Originally posted by Buffdaddy How about if I epoxy the ones that need to be drilled? Epoxy won't be good because it might not come off the plastic and if you do manage to get it off, you'll probably ruin the plastics finish in the process. |
