Anyone here good with METAL working?
Old 08-21-2006, 08:09 AM
Shirl's Avatar
Here's the deal: got a set of stainless door sills (won't name the company cuz I'm not too 100% satisfied with them). Anyway, the edges of them are jagged, a little crooked AND the top edge of the sills are WAVEY. This pissed me off the most, because it's not an easy fix. I emailed them asking for a better set and they said that all the sills are like and that they don't have time to make them perfect, so basically I'm on my own and to use sand paper. (Gee thanks. Like I knew I was spending $125 for crap workmanship.)
So I start sanding last night. AND BOY DO I SAND with heavy grit (I think it was 220 or so). I sanded these damn things at least an hour until my hand felt like it was going to fall off.
They look better, but still have imperfections. I cannot for the life of me get the waves out on the top edges of the sills. It looks some fool cut these with a jig saw.
QUESTION IS:
Is there a machine or other form of sanding I can do to bevel the edges???
Shirl is offline
Old 08-21-2006, 10:38 AM
ROUDA's Avatar
Re: Anyone here good with METAL working?
do you have any pics.
ROUDA is offline
Old 08-22-2006, 12:52 AM
IdahoLT1's Avatar
the bad thing about stainless steel is that it will show every scratch. Im not sure what you mean by "wavey". did they cut the edges crooked or is the metal bowed. if its bowed it is probably due to too much heat. pics would be nice
IdahoLT1 is offline
Old 08-22-2006, 05:46 PM
stangkilla91's Avatar
if you mean the edges are just not straight and they are rough, then go buy a dremel tool or a small grinder (dremel would probably be better for precision work though), mark off what it will take to make the edges like you want, and grind away. be careful not to go too far, remember its easier to take off than it is to add.
stangkilla91 is offline
Old 08-22-2006, 08:12 PM
Shirl's Avatar
I got it much better today using a fine file and rough sand paper. I then buffed them out with compound and then finished them with Mother's polish. Way too much effort though, for a $125 set of door sills. Took several hours of work. Installed them this evening. They look real nice though...
Shirl is offline
Old 08-22-2006, 10:21 PM
oneslowz28's Avatar
could you please pm me the companys name becuse i do not want to go with them when i order my bilit stuff
oneslowz28 is offline
Old 08-22-2006, 11:43 PM
camaro_chic17's Avatar
Could u pm me the company's name as well? I eventually want to get stainless steel door sills and I don't want to deal with a company that doesn't stand behind their products like that..
camaro_chic17 is offline
Old 08-23-2006, 08:07 AM
Shirl's Avatar
PM'ed you both with the info.
Shirl is offline
Collector Car
01-05-2015 10:58 AM
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
Evilfrog
08-07-2002 11:36 PM
Quick Reply: Anyone here good with METAL working?
