is that normal?
Old 12-04-2002, 10:59 AM
Iratate4k's Avatar
Question is that normal?
okay, after getting out the bitch mobile I noticed upon walking into the house that there was a hissing sound that sound as if the tire was leaking but it wasnt. So I go to get a look close and I see it wasn't coming from the tire at all, no, in fact it sounded as if it were coming from the upper left side of the hood (looking at it from the front). But after a few seconds the sound starts to fade away and I really havent gave it much thought but I thought since I'm on this site I might as well ask to know wut it is....
Iratate4k is offline
Old 12-04-2002, 12:16 PM
Aaron91RS's Avatar
On what car? My electric fuel pump has kept running awhile and whined in back and made funny sounds up front. Thats on a carb car though.
Aaron91RS is offline
Old 12-05-2002, 05:08 AM
Suspended
BROKKANIC's Avatar
Residual pressure from your air pump? Could be a number of things.
BROKKANIC is offline
Old 12-05-2002, 06:53 AM
Lars's Avatar
Brake Booster vacuum line/connection
Lars is offline
Old 12-05-2002, 07:37 PM
stevem's Avatar
if you have a/c it could be the system equlizing the pressure inside
stevem is offline
Old 12-06-2002, 02:18 AM
oil pan 4's Avatar
If it is the A/C equaling out that's not good it's called migration.
I would check vacuume lines, do you have power breaks after you turn off the car?
You should be able to push the break down a few tmes before it turns into a brick.
oil pan 4 is offline
PopoFormula
10-12-2015 04:19 PM
WobblySausage
10-07-2015 10:09 AM
Hal Fisher
09-30-2015 09:03 PM
SEOJustin
09-24-2015 04:39 PM
plattted
9
09-20-2015 11:23 AM
Quick Reply: is that normal?
