yo guys i need a lil help on this
Old 08-10-2004, 11:58 AM
mb^
mb^'s Avatar
ok i got this 1988 camaro v6 (sucks i like v8's)
Its 5sp i need to kown if a v8 3rd Gen Engine will work in it wth out puting a new Transmission in
and were can i get a good v8 3rd Gen Engine or Lt1 for not to much ? (I kown that a lt1 would need work to work in it)
ok now guys i'm all new to this car i'm a 300zx guy too so i'm sry if i'm hella nooby haha
ty so much guys
mb^ is offline
Old 08-10-2004, 12:15 PM
Ucantcme57's Avatar
Re: yo guys i need a lil help on this
Think you can get a LT1 and 6spd for cheaper than 6k, with harness and ECM.. all will go right in!
Ucantcme57 is offline
Old 08-10-2004, 01:07 PM
mb^
mb^'s Avatar
do you kown a/b the v8 3rd Gen Engine working wth the 5sp Transmission ?
mb^ is offline
Old 08-10-2004, 02:34 PM
krazzycowgirl's Avatar
Yes a 350 will bolt up to your Tranny all you have to do is some minor mods ( I dont know what) YOu might want to head over to www.thirdgen.org & ask those guys.
krazzycowgirl is offline
Old 08-10-2004, 03:18 PM
firebirdjosh's Avatar
The tranny will need a new bellhousing to bolt up, and it won't be able to handle the power from what I was told. You have to swap the engine and tranny, plus quite a few other parts (ECM, fuel pump, headers, etc). If you have to ask then you are probably going to be paying someone to do it for you, and in that case just buy another car. I am in the same situation and I'm putting money down on a good 350 for my 1980 camaro (my race car as opposed to my V6 crusing car).
firebirdjosh is offline
Old 08-10-2004, 04:34 PM
mb^
mb^'s Avatar
no man i kown a lot a/b cars
i'm new to the 80's camaro thats y i sayed
I will be doing all the work ty
but ty for the info Iwill get a new tranny too
mb^ is offline
Old 08-10-2004, 07:21 PM
PyRo9862's Avatar
For the thirdgen V8 I would just find a wrecked donar car. Then everything you need is right there, no running around junkyards looking for a little part that's missing. Wrecked thirdgens are cheap enough that if you have the room thats the way to go you could probably make half your money back parting the rest of the car out too.
I thought quite a bit of work was required to get the LT1 into a thirdgen, or was it the LS1 that was a PITA? I recall somthing about the AC not fitting right as well. As was already said go to thirdgen.org there are a bunch of threads on it.
PyRo9862 is offline
Old 08-10-2004, 07:30 PM
Zepher's Avatar
You can use your V6 tranny.
These are what you need to get
V8 Flywheel
V8 Bellhousing
V8 Pressure Plate
V6 Clutch Disc
An LT1 or L98 motor will probably tear the tranny to shreds the first time you launch it hard. A 305 should be ok for the tranny.
Zepher is offline
Old 08-10-2004, 07:38 PM
Did you mean...
"No man, I know alot about cars, however I'm new to the 3rd gen camaros. I will be doing all of the work. Thanks for the info, I will get a new tranny too."
carguy0119
04-11-2016 11:11 PM
rednekrocketeer
04-20-2015 09:17 AM
94Z28LS1toLT1
02-26-2015 07:47 AM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: yo guys i need a lil help on this
