Removing the A/C system...
Old 08-13-2004, 06:40 PM
Randy Capone's Avatar
Hi,
I'm actually looking froward to removing the whol A/C system on my car, since it takes up too much space under my hood, and I would like to have more room while working in it...
I would like to know if it's possible to do it by myself? If so, how?
Thx.
Randy Capone is offline
Old 08-14-2004, 11:57 AM
Marc 85Z28's Avatar
Re: Removing the A/C system...
Take the car to a certified/qualified repair shop to have the refrigerant recovered from the vehicle. If you still have R12, you might find a shop that will do it for free, in exchange for the R12. If you can't find a shop to do that, the cost will be minimal.
Then, start removing parts! It's pretty simple really. Just unbolt and remove everything, no special tools needed. Since you're looking for more room, install the proper AC delete heater box available from EBay, these classifieds, or www.thirdgen.org 's classifieds. Your looking for an "AC delete box" or a "1LE AC delete box". If you have a serpentine drive belt system, you will also the need the "AC delete" pulley or "1LE AC delete pulley".
When asking for advice, it helps to provide us with the year, model, and engine of the vehicle that you have
Marc 85Z28 is offline
Old 08-14-2004, 02:08 PM
slayer6x6's Avatar
Ah, just pull the lines off and let it fly
slayer6x6 is offline
Old 08-14-2004, 05:43 PM
Marc 85Z28's Avatar
Don't post anymore... it just makes you look dumber
Old 08-14-2004, 06:18 PM
Dave89IROC's Avatar
freon venting = $25,000 fine
Dave89IROC is offline
Old 08-14-2004, 07:18 PM
slayer6x6's Avatar
Take the compressor out of your *** because I was joking. And I am MACS certified so I do know the effects and fines misuse. But I guess Im not allowed to post here anymore because douchebags like you cant take a joke.
Old 08-14-2004, 11:53 PM
firebirdjosh's Avatar
I think there are people that may actually listen to you, that may have been why some members are upset.
firebirdjosh is offline
Old 08-15-2004, 10:06 AM
Marc 85Z28's Avatar
EXACTLY! Especially so with a new member with all of 3 posts. I must have missed the sarcasm, much like everyone else. Next time use better judgement slayer6x6.
Old 08-16-2004, 06:17 AM
Ok, good, I'll bring the car to a shop to do a purge... That's what I tought...
After that, I'll be finally able to change my 4 remaining spark plugs! Btw, it's a 91' Z28 with a 350.
Old 08-17-2004, 11:51 AM
Marc 85Z28's Avatar
I sure hope that isn't the main reason behind removing the AC! The passenger side plugs can be reached much easier from below than from above.
BTW - Headers make plug changes on our cars very easy. I can do mine in under 15 minutes, all from the top, without the AC interfering.
08-05-2015 08:35 AM
MikeWhitener
08-02-2015 06:17 PM
4586
07-31-2015 06:03 PM
RX Speed Works
07-24-2015 02:25 PM
07-17-2015 02:47 PM
Quick Reply: Removing the A/C system...
