rear end
Old 07-06-2004, 04:04 PM
durtybird's Avatar
Question rear end
can i put a 4th genereration rear end in a 3rd genereration easily
durtybird is offline
Old 07-06-2004, 07:57 PM
aklim's Avatar
I thought the length is not correct in that it is too long. So, what is your defination of "easily"?
aklim is offline
Old 07-06-2004, 08:28 PM
Stephen 87 IROC's Avatar
It's a direct bolt in however a fourth gen diff is 2" longer on each side so you either need to use fourth gen rims, buy some rims with more backspace or live with your tires sticking out of the fenders an extra 2".
Stephen 87 IROC is offline
Old 07-06-2004, 10:46 PM
durtybird's Avatar
easy as bolt right in and ill prolly get rims off a 4th gen
Old 07-07-2004, 01:23 AM
Zepher's Avatar
If you use the front/rear offset 16" 3rd gen wheels, it will look a little better. If you have 15's or other sizes that are the same offset for the front and rear, the rear will stick out noticably.
Here is my Formula with rear offset 16" GTA wheels with an LS1 rear off of a 98 Firebird,
And this is what a non-rear offset wheel sits like,
Zepher is offline
Old 07-08-2004, 04:06 PM
Marc 85Z28's Avatar
93-97 4th gen rears are almost 4" wider than you're 3rd gen rear. The later 98-02 rears are just over 3" wider than your rear. Regardless of width, all suspension locations and provisions are the same. If converting to a rear disc setup, you will need e-brake cables for an 89-92 car with the PBR rear discs.
Marc 85Z28 is offline
Old 07-10-2004, 09:29 PM
quickchicken's Avatar
Zepher, the pics of your formula. was that reg rear offsets with a 4th gen rear? or was that front offsets on a 4th gen rear?
quickchicken is offline
Old 07-11-2004, 02:57 PM
Zepher's Avatar
Those are rear offset wheels on the 4th gen rear.
Zepher is offline
Old 07-11-2004, 03:10 PM
ok, thanx. is this a pic of fronts on a 4th gen?
http://www.transamws6.com/pics/4th_gen_rear.jpg
Old 07-11-2004, 04:16 PM
Zepher, whats the widest tire you can safely run with front ofsets on the rear?
Old 07-11-2004, 06:41 PM
Zepher's Avatar
I was running 255/50/16's and they fit fine,
Zepher is offline
10-31-2016 11:09 AM
blac94Z
03-02-2015 06:03 PM
Chet1185
02-04-2015 09:51 PM
jcamaro95lt1
01-24-2015 08:21 AM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
Quick Reply: rear end
