Pros and Cons to the Holley HSR
Old 06-02-2004, 09:10 PM
97WS6SCharged's Avatar
Just like the title says. What are the pros and cons to using the HSR? I know it makes better power higher up than the stock TPI is capable of, but what about installation hassles, wiring mismatches, things of that nature. What are the major headaches that I'm looking forward to?
97WS6SCharged is offline
Old 06-02-2004, 09:27 PM
aklim's Avatar
You'd have to make your own fuel lines to run from the stock system and your throttle linkage may or may not clear, depending on the one you use.
aklim is offline
Old 06-02-2004, 10:41 PM
Should have mentioned, it's going into an S10 which is currently gutted. So fuel system/lines are no problem cause I have to plumb them anyways. Also, I need a new throttle cable so... any other things I should know about?
Old 06-02-2004, 11:25 PM
krazzycowgirl's Avatar
Depending on which engine/wireharness its going to match up with you will need a new chip. If its out of like an 87-88 Fbody 350 then you have to find a way to delete the cold start injector.
Oh its not Street legal so if you have to have it inspected you will have to do some mods to it that way it passes smog.
also go to www.Stealthram.com
krazzycowgirl is offline
Old 06-03-2004, 01:07 AM
I've been looking on Stealthram.com, just couldn't really find what I was looking for. Currently I've got a brand new Painless wiring harness for a TPI car that is still in the box along with a factory computer. I've already talked to my tuning guy about burning a chip for the thing, so that's all set. And there's no emissions here in good old Jacksonville. I've almost got all the parts for the engine that I need, minus the intake. All I need now is a new pair of doors so I can put an interior in without having to worry about weather screwing up everything.
Quickss96
01-29-2016 05:56 PM
9t4lt4z28
10-02-2015 10:28 AM
Z Power
09-19-2015 11:19 PM
95craz28
11
09-12-2015 07:47 AM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: Pros and Cons to the Holley HSR
