manifold coolant temp sensor
Old 10-31-2010, 06:26 PM
Wishmaster's Avatar
is it bad to run with it disconnected? i know it will throw i code but?
Wishmaster is offline
Old 10-31-2010, 09:46 PM
cars3's Avatar
Re: manifold coolant temp sensor
Why would you want to? There must be a reason why you want to do this!
cars3 is offline
Old 10-31-2010, 09:50 PM
Wishmaster's Avatar
because im trying to pin point a problem that has been going on for to damn long...and i kinda wanna sell the car and would like to get it fixed.
Old 11-01-2010, 05:46 PM
BigBadLou's Avatar
It's not too bad to run with the CTS or IAT disconnected but you will run likely richer than you need, thus fouling plugs and wasting a lot of fuel. It is acceptable just for testing but I wouldn't drive it like that to work every day.
You can test the CTS and IAT sensors with a simple ohm-meter if you need. They do go bad, just like any other sensors.
Hope this helps.
Lou
BigBadLou is offline
Old 11-02-2010, 12:46 AM
cars3's Avatar
Hope this helps.
Lou
I do not want to hijack this thread, but Lou how do you check the IAT. I think I may have a problem with it on my formula 350 from what people are telling me.
cars3 is offline
Old 11-02-2010, 09:23 AM
BigBadLou's Avatar
I assume you have a TPI intake? You can test it the same way as a CTS (since it's actually a CTS in there that's measuring the heatsoaked manifold instead - Chevy does not believe in measuring the real AIR temperature with its Intake Air Temp sensor ).
You can pull the sensor out and measure its resistance at several temperature points.
Use this chart for resistance reference: http://www.thirdgen.org/techboard/at...ase-ctsmat.gif
If you measure the sensor cold, let's say outside on a 50-degree day, you should see several kilo-ohms in resistance (around 5).
If you put the sensor in the freezer for half an hour, you should be able to measure around 25 kohm.
Put the sensor in a boiling pot and measure it at least at boiling point (around 180 ohm). You can also measure points in between, using a reference thermometer, it's up to you. Just like in the good old days of school lab work.
That will tell you whether the IAT/CTS is out of range. Sometimes they just stop reading at all.
Let us know what you find.
Lou
warmeck
04-27-2015 04:34 PM
AlaskaZ28
01-01-2015 12:30 PM
AlaskaZ28
12-10-2014 02:39 PM
AlaskaZ28
12-10-2014 02:37 PM
91Bird305
08-08-2002 12:36 AM
Quick Reply: manifold coolant temp sensor
