harmonic balance/flexplate
Old 06-21-2016, 12:08 PM
WRuiz's Avatar
I'm building a stock L98 for a 1990 Iroc. Stock inside. I'd liketo know if I need to buy an internally or externally balanced flexplate. Also,does the same apply to the harmonic balancer? I found a stock harmonic balancerat OE parts HQs (oehq.com) for around $70. I believe all 350 are internallybalanced. Does that mean the flexplate and/or harmonic balancer have tobe internally balanced? Or neutral? Also, can you recommend a good combo?Thanks
WRuiz is offline
Old 06-21-2016, 07:17 PM
Re: harmonic balance/flexplate
The flywheel or flexplate for a 1-piece rear main seal 350 has a small weight on it to compensate for the changes made to the crank rear flange for the 1-piece seal. Damper is neutral balance.
Injuneer is offline
Old 06-22-2016, 08:12 AM
WRuiz's Avatar
Thanks for the reply. So when shopping for parts I should ask for an external balanced flexplate and neutral damper, correct?
WRuiz is offline
Old 06-22-2016, 11:05 AM
The terminology can get confusing. The technical hardliners will insist that the engine is internally balanced, even though it requires the small counterweight. In their mind, the flywheel is an "internal" part of the engine. Not sure what to tell you.
See this article for what is required:
1955-1996 Chevy Small-Block Performance Guide: Crankshafts Manual (Part 2)
This photo (in the middle) shows the "batwing" weight on a 1-piece RMS flywheel:
Injuneer is offline
cmaddox03
01-04-2016 07:29 AM
Ben Jones
12-06-2015 09:42 PM
doza's z28
10-21-2015 07:16 AM
kandied91z
09-14-2002 08:37 PM
TechCam97
09-12-2002 07:20 PM
Quick Reply: harmonic balance/flexplate
