gauge cluster!!!
Old 06-12-2004, 08:47 PM
17wth85z28's Avatar
gauge cluster!!!
i got 2 3rd gens now, would a gauge cluster from a 90-91 fit? my camaro is a 84 Z28
17wth85z28 is offline
Old 06-12-2004, 10:07 PM
91BigRedz28's Avatar
You could (and in order to do what you want, probably have to) replace the whole dash, but I think the shape of the gauge cluster for an 84 itself is different from the 90-92s. Also, the 90-92s are electronic, so you'd need all the wiring and such, which I dont think the drivetrain will physically accept. You can get conversion kits for the transmission (if its a 700r4) to make the crossover to the electronic readout, but I dont know what you'd do about the others, like the oil, temp, and others...
For me, it would be WAY too much work...I'd probably just either stick with the 84's cluster, or buy an aftermarket one...if I had all the tools and ambition (and craft), I might make my own cluster, which could be really cool if you took your time on it.
91BigRedz28 is offline
Old 06-12-2004, 10:10 PM
Not the WHOLE dash...but everything around the steering column...you knew what I meant though, right?
Formula Steve
09-19-2023 08:31 AM
IndyZman
10-22-2015 02:17 PM
drt
09-27-2015 04:39 PM
RX Speed Works
09-11-2015 03:31 PM
jackpawt883
09-10-2015 08:53 PM
Quick Reply: gauge cluster!!!
