88 Z28 bearings out on the crank
Old 04-05-2010, 07:35 PM
benton_11's Avatar
I just bought a 88 z28 camaro and it has the tpi. it is bored 30 over and not sure why it blew up. but all the bearings went out on the bottom end. it was recently rebuilt and had less than 10 miles on the run. not sure what went wrong. looking for thoughts. not sure what it has for a cam if its original or not. thinking not. i need some thoughts.
benton_11 is offline
Old 04-06-2010, 07:06 AM
R_ADKINS80's Avatar
Serveral possible answers as to why it blew:
1: Bearings installed incorrectly
2: Bearings installed DRY with no assembly lube
3: faulty oiling system (bad pump, blocked oil passages ect....this could go along with #1, Bearings installed backwards ect could block the oil passages that feed the bearings.)
4: Bearing tolerances could have been too tight or too loose.
R_ADKINS80 is offline
10-31-2016 11:09 AM
Brandon Wittmer
12-20-2014 09:51 PM
1996LT1Z28
12-01-2014 01:01 AM
chuyz28
11-25-2014 11:14 PM
1LEThumper
07-14-2003 12:45 PM
Quick Reply: 88 Z28 bearings out on the crank
