305 vs 350
Old 07-20-2010, 11:47 PM
Texaz28's Avatar
305 vs 350
I have a 305 and a friend gave me a deal ($100) on a stock Vortec short block out of a '97 Tahoe. Being that I am HP biased and like TPI (weird huh?) I have to admit I always found the 305 builds more interesting. The bottom line is I still think my 85 Z28 deserves the life it never got from GM which is to be a true performer so the 350 is most likely going in. Who has done the swap, how big was the difference?
Just so I dont get asked, I have never had a 350 TPI car. I have a few 305's, 1 350 carb 3rd gen, a 95 Z28 M6 and 98 TA 4L60E. I sold the TA for another third gen.
Texaz28 is offline
Old 07-21-2010, 11:11 AM
quickchicken's Avatar
when you swap in the 350 you will need larger injectors (22 lbs) and a chip burned to run them. you will also choke out sooner with the 350 vs the 305 running a TPI.
quickchicken is offline
Old 07-23-2010, 10:30 AM
GRIDERMAN87's Avatar
Its almost exactly the same everything mounts up you may need to change the pulley system.
GRIDERMAN87 is offline
Old 07-23-2010, 11:15 AM
BigBadLou's Avatar
A Vortec short block?
Two options:
- You'll need L98 heads to bolt the TPI intake on.
- You can put the better flowing Vortec heads on but you'll have to redrill them to accept the TPI lower intake bolt pattern (not a bad job).
Might I suggest full-roller rockers while you're at it? One of the cheapest HP gains out there.
Well, since the intake is off anyway, why not put a better cam in there? LT4 Hot Cam for higher HP up top or the ZZ4 torque cam for more torque down low and better fuel economy.
Yes, you will see a noticeable difference, especially if you let the engine breathe with headers and decent exhaust. My 305->350 swap got me gains not only in power but in fuel economy as well (due to a more efficient engine configuration). I went from 18mpg to 25mpg.
And don't forget to buy wipes. Lots of 'em!
You'll need plenty to wipe the grin off your face afterwards!!
Lou
BigBadLou is offline
Old 08-05-2010, 03:10 PM
fbody93's Avatar
I think eldbrock makes a lower tpi vortec base.
fbody93 is offline
HAWG
09-25-2015 11:41 AM
Tarizza
09-20-2015 03:26 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
Quick Reply: 305 vs 350
