2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
[Wheels] Need more info for wheels
Old 11-18-2009, 01:08 PM
racingracing's Avatar
Hi guys, I just joined the club I got a LT with RS package, and are about to purchase some 18" winter wheels package. I've done a lot of google and search on our site, but there still some info that I'm missing and hope you guys would know:
Lug nut size: 14x1.5mm?? (from what I found on McGuard site)
Hub Size: ?? (someone said 67.1mm?)
Lug nut seat: I believe conical?
Hex size: 22mm (from lot of place that I found)
If I got this info, I may see if I have any previous lug nuts that I have from other cars... to save some money
Thanks for any info in advance!
racingracing is offline
Old 11-18-2009, 06:08 PM
sorry I meant to say "Need" more info for wheels on the topic, don't know why I missed the "Ne" there and I couldn't change it now :P
Old 11-19-2009, 06:25 PM
Admin Emeritus
JasonD's Avatar
What wheels are you getting? They may require different lugs than what the factory wheels require.
Fixed the title.
JasonD is offline
Old 11-20-2009, 07:59 AM
Thanks for fixing the title Jason.
From what I've found so far:
Hub Size: 67.1mm
Stock Lug nut seat: conical
Hex size: 22mm
Old 12-01-2009, 05:13 AM
What Jason is explaining is that aftermarket wheels may not use the same type of lug nuts as the factory wheel. Yes, you have to match the thread pattern
(diameter and pitch), but not all wheels use a conical lug seat. Some drag wheels, for example, require shank type lugs. The seat type is determined by the wheels, not the car you are putting them on.
Injuneer is offline
Old 12-01-2009, 06:59 AM
Admin Emeritus
JasonD's Avatar
Thanks for clarifying, Fred! That is what I was referring to.
JasonD is offline
BandDirector Blk98ZM6
02-20-2015 07:42 AM
dpw21562
01-23-2015 04:58 PM
Jason Short
01-19-2015 06:33 PM
bernie1951
12-10-2014 10:03 AM
squarehead
11-21-2014 08:02 PM
Quick Reply: [Wheels] Need more info for wheels
