2010 - 2015 Camaro Wheels, Tires, Brakes, Suspension Discussion for 2010 - 2011 - 2012 - 2013 - 2014 - 2015 Chevrolet Camaro Wheels | Tires | Brakes | Suspension
2011 2SS Tires
Old 12-27-2011, 03:01 PM
gomezcorp's Avatar
2011 2SS Tires
About to replace the stock P-Zero tires of Front 245/45-20 to Nitto INVO 255/35-20 and Rear stock 275/40-20 to Nitto INVO 295/35-20 and place on the stock 20"rims. Does anyone foresee a problem? Thanks.
gomezcorp is offline
Old 12-30-2011, 09:09 AM
km9v's Avatar
Re: 2011 2SS Tires
Why aren't you getting the stock size?
km9v is offline
Old 12-31-2011, 09:17 AM
wastintime's Avatar
Re: 2011 2SS Tires
I only forsee one issue, which is with the rear tires. There's a lot of room under the Camaro fenders, we're running a 295/305 setup granted with very different wheels than stock, but still... there's room for wide tires. You can't get too wide in the front on stock rims before you worry about hitting the springs and/or spring perch, but only adding 5mm of rubber to the inside shouldn't be a huge issue.
I'm relatively sure you have the inner clearance with a 20" on the rear with stock offsets, you wouldn't with smaller diameter wheels. My concern with the rear would be you're mounting a tire designed for a 10.5" wheel on a 9" wheel, which is 1" outside of the approved rim width for a 295/35... everyone rolls there eyes at approved rim widths, but if you've ever seen a tire pull off a rim while cornering, it matters and can ruin your day... I'd just be aware of that.
wastintime is offline
Novo
Wheels and Tires
14
10-12-2015 11:20 AM
cmsmith
09-14-2015 09:25 PM
08-05-2015 08:35 AM
Slayer
07-04-2015 03:06 PM
Quick Reply: 2011 2SS Tires
