Z06 Rims - A few questions
Old Apr 11, 2007 | 09:07 AM
WheelmanZ28's Avatar
Hey All,
I'm sure these questions have been asked a million times, but I am a wheel noob and I would appreciate your help. I did a search and it answered a few of my questions, but I'd rather hear the answers for my setup.
I have an 01 WS6. I recently found a good deal on black Z06 wheels with a chrome lip. I plan on running 17x9.5 in the front and 18x10.5 in the rear.
Questions:
1. First of all: Will these fit!? Will I need spacers? other adjustments?
2. What tire size/brand would you suggest? I would like something with decent traction, maybe a drag radial in the rear, and something moderate for the front.
Thanks as always for helping me out!
Old Apr 11, 2007 | 11:35 AM
Moshbmx1's Avatar
If the backspace and offset is right, which i assume they are then they should fit yes. Depending on the rear tire you may need to do some hammering and or grinding on the rear caliper (not for sure) A good rear tire to run would be a nitto 555 or something along the lines of a street legal DOT tire if you plan on running the car on the street. As far as front tires you can run a variety of things. I have Kumho tires all the way around but i will get nittos for the rears once i burn these off.
Old Apr 11, 2007 | 11:52 AM
copboy736's Avatar
Check out the sticky at the top of the wheels section. I got alot of my answers from there and you can too probably.
As far as the tires, I have heard several different peopls mention Nitto, but also BF goodrich. I dont know personally though, since I have not gone to a performance tire yet. I am still saving for the rims and tires for mine.
Old Apr 11, 2007 | 01:59 PM
I did read through there a bit actually, VERY nice guide.
However, and i may have overlooked, but I didn't see these sizes mentioned directly, which is why I am asking for help.
Anyone here running these sizes that can share their experience?
Thanks!
Old Apr 11, 2007 | 02:55 PM
You need to know the offset of the wheels. Impossible to answer the questions without that info. Are they OEM or aftermarket - I have the OEM dimensions?
And.....
http://camaross.com/forums/showthread.php?t=513982
Old Apr 12, 2007 | 09:28 AM
Thanks as always Fred. Got the dimensions of the offset from the vendor.
17x9.5 +54 mm
18x10.5 +58 mm
The vendor assured me these would fit fine, but I wanna hear it from The Man himself
Thanks again.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Dec 7, 2014 06:01 PM
