Will 10.5" Wide x 18" with 50MM Offset fit in FRONT? 4th Gen LT1.
Old Feb 24, 2010 | 04:17 PM
HardcoreRM125's Avatar
Anyone know if an 18x10.5" will work up front on a LT1 car?
I found a set of (4) all black Z06 rims locally but all four are 10.5" wide. I would likely run something like a 315/30/18 rear and 275/35/18 front if I get these.
Hoping a 10.5" wide wheel will clear from rubbing in the front on a 4th Gen. with reasonable size tires.
* READ the sticky at top already. Could not see if those wheels would NOT fit up front or not *
Thanks,
Joe
Old Feb 24, 2010 | 04:39 PM
v7guy's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=597727
Old Feb 24, 2010 | 06:17 PM
Thanks buddy ...
Did some math - from your mounting surface to edge of rim should be 195.7 MM and these should only stick in the wheel well 191.35MM
So technically, I should be able to run these. Will be using a narrower tire up front than you. As long as its not taller I am good
What size spacer would you estimate will be needed to use on stock brakes?
Old Feb 24, 2010 | 06:50 PM
v7guy's Avatar
for some reason I want to say it's a 1/4 that needed, but I don't remember for sure, it's been awhile since I checked. My advice would be to get the wheel and put it on and then measure for a spacer that'll put it right where you want it.
Old Feb 24, 2010 | 07:09 PM
Thanks bud.
By chance, can you use the stock wheel studs?
Old Feb 24, 2010 | 11:59 PM
69z-28's Avatar
the spacer is 3/16 IIRC. i had a 295-35-18 on an OEM 18x10.5 and it fit the front fine with no rubbing issues although the lip of the wheel was EXTREMELY close to the top of the spindle.
Old Feb 25, 2010 | 02:18 AM
v7guy's Avatar
in my case I couldn't use the stock wheel studs. there wasn't enough thread engagement on the lugnuts, I replaced them with some ARPs
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
4586
Dec 31, 2014 02:21 PM
Dec 4, 2014 11:56 AM
firebirdude
Aug 7, 2002 07:31 AM
