Widest Tires?
Old Aug 24, 2004 | 09:15 PM
ChrisUlrich's Avatar
Widest Tires?
What are the widest rims/tires that can fit on a 96 TA? I want 17-18 rims if at all possible.
Are there any bad benefits from wider tires other then tire prices?
Old Aug 24, 2004 | 09:24 PM
1msfyter's Avatar
Re: Widest Tires?
Corvette rims bolt right up, I have the 17" &18" combo 245/45/17 fronts
and 275/40/18"s out back. Just check the offset. 56mm is prefered.Correct me if Im wrong. You cna go as high as 315"s in the rear with some major inner fender beating and fender lip rolling. Do a search it has been discussed a lot and a lot of guys here are running big tires and rims.
Old Aug 24, 2004 | 09:32 PM
jeepz28's Avatar
Re: Widest Tires?
I have 315/35r17 and the zr1 17x11 and they fit right in the only thing is that if you rase the back of the car without rasing the axel and all it hits the bumpstops
Old Aug 24, 2004 | 09:54 PM
Re: Widest Tires?
Not sure what "275/40/18" means other then I think the "18" means 18" rims... I just want the widest tire possible from left to right because I freakin love the way wide tires look... freakin insane.
Can someone explain to me what the "275/40/18" stands for?
Old Aug 24, 2004 | 10:07 PM
bowtieforpower's Avatar
Re: Widest Tires?
275--width of tires
40--how tall the tires are
18--size of rim it fits
Old Aug 24, 2004 | 10:13 PM
jeepz28's Avatar
Re: Widest Tires?
Reading Tire Sizes:
Example Size: P205/60R-15OWL
P - Passenger
Tire sizes can also start with the following:
BP - Cosmetic Blemish Passenger
LT - Light Truck
205 - Width in millimeters of tire’s tread.
60 - Aspect Ratio - Percentage of tread width that equals the sidewall height.
R - Radial
The letter “R” can also include the following:
HR - H=Speed Rating
VR - V=Speed Rating
ZR - Z=Speed Rating
15 - Rim diameter in inches.
Other letter combinations include:
OWL - Outlined White Lettering
RWL - Raised White Letters
W - Whitewall
B - Blackwall
ORWL - Outlined Raised White Letters
WW - White Wall
BW - Black Wall
Tires can also be listed as:
205/60R-15 93H
93H - 93 Load Index, H Speed Rating
Light Truck (LT) sizes can include a letter at the end of the size.
LT265/75R-16/C
C - Load Range
Further information on all of these topics can be found at our “Info Center”.
from
tire.com
Old Aug 24, 2004 | 10:20 PM
lillbush5555's Avatar
Re: Widest Tires?
how about some..335-40-17
Matt
Old Aug 24, 2004 | 10:42 PM
Re: Widest Tires?
I didn't seen one describing the width of it?
Another words... The part you would see if you were looking at it from the rear.
Old Aug 24, 2004 | 10:43 PM
Re: Widest Tires?
205? Thats the width? But in millimeters?
So then what does a stock 96 WS6 come with? Opposed to the new Vette or whatever... I want the wider tires!!
Old Aug 24, 2004 | 10:54 PM
S.J.S.'s Avatar
Re: Widest Tires?
Matt
Ummmm ... NO. Haven't seen anyone with more than 315's. I run 315's and it was fine with the stock shocks even with the drop. But when I went and changed them to Bilsteins I cut my tire even though I have the fenders rolled.
Old Aug 25, 2004 | 08:20 AM
BlownF1's Avatar
Re: Widest Tires?
I'm running 315/35-17's on the rear as well. There is at least one guy in SoCal running 335/30-17's all the way around...takes special offset rims and a bit of massaging. 315's are the widest I'd go and even then there is a bit of inner fender work you should do to keep them properly clearanced. AFS sells SS style rims with the correct offset and there's nothing a 3lb sledgehammer can't fit!
Old Aug 25, 2004 | 09:07 AM
BPS's Avatar
BPS
Re: Widest Tires?
My car is lowered and has gfx so you don't really see the tires but here is a picture of my 315's on a 12 bolt prior to instalation to give you an idea of tire to axel comparisons.
http://www.members.shaw.ca/bps-z28/i...o/P1020317.JPG
the tires are 12.5 inches wide and are on 11" zr1 vette rims
The major downside is cost - good tires and nice rims will set you back a pocketfull of coin. Traction is a better but front tracking is harder with wider tires.
a few folks here have 315's all round and a couple have 335's in the rear.
Old Aug 25, 2004 | 09:24 AM
Zack's Avatar
Re: Widest Tires?
275/40/17
Old Aug 26, 2004 | 07:31 AM
jer4251's Avatar
Re: Widest Tires?
http://community.webshots.com/user/jer4251 I'm running 335 17's.
click on the zr1's to see them
Old Sep 13, 2004 | 10:14 AM
Will84's Avatar
Re: Widest Tires?
You sure they're all the way around? I don't see how that would work.
...even then there is a bit of inner fender work you should do to keep them properly clearanced.
I've seen where a lot of guys have had problems, but I never had to modify anything. I did grind a little off the edge of the jounce bumper mount for the hell of it... but that's all.
