widest tire 17x9.5 in rear
Old Jan 15, 2007 | 07:45 PM
TIPAD5050's Avatar
whats up all
just wanted to know if 315/37/17 will fit in rear without rubbing
thanks for any info
Old Jan 15, 2007 | 08:38 PM
seawolf06's Avatar
295 is absolutely the widest tire I'd run on that rim.
http://ls1tech.com/forums/showthread.php?t=120716
Old Jan 15, 2007 | 09:02 PM
CamaroRacing12's Avatar
285's r preferred check the FAQ at the top of this site.... anything bigger u wont get the whole surface area of the tire to the ground...but i have seen 315's done b4
Old Jan 15, 2007 | 10:19 PM
Compstall's Avatar
I also wouldn't go bigger than 295 or so. Anything over 300 should have a ten inch rim or bigger.
Old Feb 6, 2007 | 04:02 PM
CALL911's Avatar
Agree with above post. You're safely maxed really at 275 on a 9.5 wheel. You could probably manage a 295, but is wouldn't look right. There's no way safely you'll get over a 300 sized tire on there though.
Old Feb 6, 2007 | 04:57 PM
Greed4Speed's Avatar
Originally Posted by TIPAD5050
whats up all
thanks for any info
Where are you going to find a 315/37?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
carguy0119
Apr 11, 2016 11:11 PM
RUENUF
Mar 13, 2016 03:39 PM
cristian1311
Mar 4, 2015 04:45 PM
