CamaroZ28.Com Message Board
-   Wheels and Tires (https://www.camaroz28.com/forums/wheels-tires-49/)
-   -   Wheel width and clearance (https://www.camaroz28.com/forums/wheels-tires-49/wheel-width-clearance-881944/)
camaro98_speed Mar 12, 2015 05:25 PM
I am looking at getting some 18x9.5" Corvette C6 Grand Sport Style Gloss Black aluminum replica wheels, 5x4.75" lug pattern +40 mm offset (6.82" backspacing) all the way around. i am thinking of either 275/35/18 or 265/35/18 all the way around as well. will i have any clearance issues?
Also, ive come across some wheels that say they are for camaros and have a 5x120.7mm pattern. Would that be a problem? I think stock is 5x4.75 (120.65mm).
Thank you
Injuneer Mar 13, 2015 10:37 AM
Re: Wheel width and clearance
The picture below is with 17 x 9.5" 49mm wheels. The offset is what is important. Tires are 275/40-17 (25.7"). With 40mm offset, your wheel will be moved about 1/3" outward. May have some rubbing of the outer edge of the tires on the front inner fender liners with the wheels at full lock, or hitting a hard bump. Back will be OK.
https://www.camaroz28.com/forums/mem...ull02-6397.jpg
Your stock tires were either 235/55-16 (26.2") or 245/50-16 (25.7"). If you had the 245's, the 275/35-18 (25.6" will be a close enough match to avoid throwing the speedo/odometer off, without a PCM reprogram. The 265/35-18 is only 25.3" diameter, and to me, thats too small - thinner sidewall exposes rims to pothole damage, increases ride harshness, and opens up the already too large gap between the top of the tire and the fender lip.... not by much, but enough.
I would consider 285/35-18 (25.8").
I've seen a number of sites where they show the 4.75" bolt circle as 120.7mm. They have just "rounded off" 120.65mm.
camaro98_speed Mar 13, 2015 03:00 PM
Thank you for the reply. What are the advantages of 285's vs. the 275's?
Sorry for so many questions, what about a wheel with 56mm offset? Would it rub?
BandDirector Blk98ZM6 Mar 13, 2015 03:44 PM
18x9.5 w/56mm offset and 275/35/18 will fit perfectly.
camaro98_speed Mar 13, 2015 03:54 PM
Awesome! Thnx!
Injuneer Mar 13, 2015 08:09 PM
285 will give you a bit more tread on the pavement, a tiny bit more sidewall, a tiny bit more fender gap fill, and get you closer to stock tire diameter, if your car came with the 235/55-16 tires.
56mm offset will move the outside edge of the tire inwards about 1/4" compared to the photo. I can post a pic of my car with 56mm in the front if you want.
camaro98_speed Mar 16, 2015 05:31 PM
Thank you. If it is not too much trouble to post the pic, sure. Thnx!
Injuneer Mar 17, 2015 07:36 AM
17 x 9.5" 56mm in the front only. 275/40-17 BFG g-Force KDW
https://www.camaroz28.com/forums/mem...4dr02-6078.jpg
https://www.camaroz28.com/forums/mem...heels-5991.jpg
