Wheel weights and effects on acceleration?
Old Feb 14, 2005 | 10:43 AM
97HUGGER's Avatar
I have just ordered a set of OE Concepts 17x11 ZR1's for the back of my 1997 Camaro SS. I am putting Nitto 555r P315/35/R17 on and after I purchased the wheels I found out the weight of the wheels are 30 pounds each. It sounds pretty heavy to me considering my stock 17x9 factory SS
wheels only weight about 21 pounds each. Does the weight of these aftermarket rims sound right or did I get some bad information from the manufacture. I haven't received the rims yet or else I would weigh them myself. Also if this is the true weight of these wheels what type of effect will this have on acceleration. If anyone has these wheels could you let me know if it has made a big difference on acceleration. Thanks.
Old Feb 14, 2005 | 02:34 PM
LPEdave's Avatar
Re: Wheel weights and effects on acceleration?
30lbs sounds plausible for a 17x11. As a data point, you could get back down to about 20lbs/wheel if you went with a bigh end (expensive) wheel. Just think, those huge 22" wheels on SUV's weigh 95-100lbs - so you could be worse off!
You'll definitely notice the feel between your old and new wheels. As far as the actuall loss of acceleration, I couldn't tell you....
Dave
Old Feb 14, 2005 | 10:20 PM
bt96ss's Avatar
My car felt slower after I put the 17 X 11's on.
Old Feb 19, 2005 | 11:51 AM
bruecksteve's Avatar
My 17x11's only weigh 25 lbs. 30 is way too much.
carguy0119
Apr 11, 2016 11:11 PM
F550maranello2
Apr 1, 2015 11:10 AM
Collector Car
Jan 5, 2015 10:58 AM
