What does wheel size effect?
Old Nov 13, 2005 | 12:01 AM
00cls1camaross's Avatar
Just wondering what wheel size effects...
thanks,
Dakota
Old Nov 13, 2005 | 12:09 AM
Camarocracy's Avatar
Re: What does wheel size effect?
It can alter your speedometer readings if you do you not correct your tire size to the changed size of the wheel.
Heavier wheels can slow the car down in the 1/4, making braking harder, and just make the car feel heavier and slower.
Also, if you go too big, you can rub your fenders and potentially destroy the tire.
Old Nov 13, 2005 | 12:22 AM
alright... why does it make your 1/4 mile times slower... is it just that fact that the motor has to turn a heavyer wheel which makes a power loss?
Old Nov 13, 2005 | 01:22 AM
If the wheel/tire combo weighs more then the factory set-up, it just takes more power to move the wheel/tire. And it's the opposite if the wheel/tire combo is lighter, it takes less power. There are pro's and con's to heavier/lighter wheels. For instance, lighter wheels will increase your 1/4 trap speed, but they can also increase wheel spin at launch do to weighing less. Heavier wheels can give a better launch due to less wheels spin from the weight, but will cost you in the 1/4 trap speed.
Larger wheels can also cause wheel sping due to having less sidewall with the tires. In drag racing, you want sidewall flex to gain traction. A thinner, meaning stiffer sidewall will not wrinkle. But in road racing/auto-x, a stiffer sidewall is preferred.
And wider wheel/tire combos give the better traction in both drag and road racing.
Old Nov 13, 2005 | 08:39 AM
mook99TA's Avatar
very good explaination I totally agree. I got 17's after having 16 stockers. My trap times increase from .1 to .15 but my 1/4 mile stayed pretty much the same.
Old Nov 13, 2005 | 11:00 AM
i see thanks for the comments guys
HectorM52
Jul 30, 2017 11:46 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
ChrisFrez
Nov 30, 2014 08:41 AM
