what is the biggest wheel and tire I can put on a stock 94 TA ?
Old Aug 4, 2004 | 08:39 PM
jaytone's Avatar
Hi
I have an annivesary 94 TA that has white wheels size 16 inch. I would like to get some chrome or polished wheels and new tires on my stock suspension
I was wondering if anyone could suggest the largest tires and rims that will fit. I also need suggestions as to whether to put smaller rims and tires on the front and larger on the rear, again I want them to fit the stock wheel wells.
Old Aug 4, 2004 | 08:49 PM
Valkyn71's Avatar
Re: what is the biggest wheel and tire I can put on a stock 94 TA ?
You can fit up to 18x11, maybe taller, on the rear, and the same on the front with some work.
Im going with 17x11 on the rear and 17x9.5 on the front, which is about as big as you can go without any modification i believe.
Old Aug 4, 2004 | 10:30 PM
kingman109's Avatar
you can fit 18x9.5 on front no prob just put mine on
Old Mar 10, 2005 | 02:25 PM
meangreen661's Avatar
do you guys think that there would be any problems with putting 18x10's on the front. I bought a set of 4 18X10 wheels for my car from a friend who had them on his T/A. He had 275/35/18 Pilot's on them and from what i can tell i don't see any kind of rubbing on the tire. I am going to just put 275/35/18 Kumho MX's on them but i was wondering if i went to a different tire would that make it rub at all. I have "heard" or people saying that they know people with 18x11's on the front but never saw it myself.
Old Mar 10, 2005 | 07:47 PM
bruecksteve's Avatar
I run 17x11's all the way around and love it!
Old Mar 10, 2005 | 08:09 PM
stang_killa94's Avatar
19X9 on back and 19x8 on front
Old Mar 11, 2005 | 10:37 AM
kingman109's Avatar
well thats the same size tire im running on my 18x9.5's in the front... sooo i dont think you'll have much of a problem. as for the rear id bump up the tire size seeing how you have 10" rims
Old Mar 11, 2005 | 10:47 AM
It's not so much the diameter as much as it's the offset and width of the wheel. I can tell you that a 50mm offset 11" wide wheel with fit, both front and rear with minor inner wheel well banging in the rear, and a 1/4" spacer in the front.
I use a 36mm offset 11" wheel in the front with no spacer and use 315/35-17's. In the rear I use a 50mm offset wheel with a 1/4" spacer in the rear with 315/35-17's.
Old Jul 11, 2005 | 11:01 AM
blind527's Avatar
Will I lose performance on my car if I have the mods listed in my sig with 17x11 in the back and 17x9.5 in the front? I want to get black ZR1's. I also want to get some nice drag radials for the back.
Old Jul 13, 2005 | 03:44 PM
Coolformula's Avatar
What do you mean lose perfomrance?? I like having 17x9.5 all the way around you can still rotate your tires. 17 inch wheels I think will be heavy and increase your unsprug weight......but 17's are worth it.....
Old Jul 13, 2005 | 03:51 PM
blind527's Avatar
Loose performance meaning.......
The wheels are way too big making my car slower and decreasing braking and cornering.
Old Jul 13, 2005 | 03:52 PM
I use 17x11's with 315's all the way around and while it might add some extra weight, it's worth it to me because of the increase braking and cornering. I would never go back with anything smaller. It's my daily street car and autocrosser.
But I'm not a drag racer. You will gain more traction (depending or tire selection) because of the increased width but you will add a few pounds, not much though.
I would try to use the same size and offset front and rear to make rotation easy.
Old Jul 13, 2005 | 03:53 PM
blind527's Avatar
Great! 17x11 and 17x9.5 it is!
Old Jul 13, 2005 | 05:15 PM
GPZ28's Avatar
I just put on some zr1's 17x11 17x9.5 no rubs no probs. 36mm front 50mm back 275 and 315's
Old Jul 14, 2005 | 12:39 PM
CHELOZ28's Avatar
stang killa...sweet ride man, those rims look great on your car......Off the subject where did you get those z28 emblems?
