Traction
Old Jul 10, 2006 | 12:34 AM
  #16
sandman63's Avatar
Re: Traction
One question, everyone says that the 10 bolts are such crappy rear ends, but what actually breaks? (yes i know, i should have done a search) the car has 67miles.
Old Jul 10, 2006 | 11:49 AM
  #17
remaxracer45's Avatar
Wink Re: Traction
that is what I wanna know. Everyone says they are junk and break but no one really says what breaks,what and how you can at least make it better without a 2k$ rear change.
Old Jul 10, 2006 | 02:24 PM
  #18
kick Z tail out's Avatar
Re: Traction
Originally Posted by sandman63
Yeah, well as stated earlier my car is stock, so am i really gunna have the power to complete roast those tires off in 3 weeks? i sure'ly dont think so. an if i do go with the ET Streets what can i expect for traction wise? thanks alot
I don't even think you need drag radials period with a stock car. If you're having substantial traction problems, you're current tires probably just plain suck.
Some good street tires will hook just fine. Especially on a stock car.
If you go to drag radials I hope you know that you won't be able to handle for crap on the street on anything more than a gentle curve in the road. I also can't stand the way my car wanders and feels mushy in a lane change when I'm going to and from the track, when I'm on my ET Street radials.
Old Jul 10, 2006 | 03:14 PM
  #19
Cool Re: Traction
kick tail what kind of times are you running? what is built about your rear end?
Old Jul 10, 2006 | 03:20 PM
  #20
ABA383's Avatar
Re: Traction
I've seen pinion gear breakage which then takes out the ring gear...There's not much you can do to make a 7.5" ring gear any bigger/stronger...The small ring and pinion is the weakness...I got lucky for 9 years before I upgraded to a 12 bolt...
My experience with an A4 with a 10 bolt and 3.42s was very positive. I never broke anything except to wear out a limited slip running BFG DRs..The 3.42 gear set has more pinion teeth which may be why it is more "durable" than 3.73s/4.10s...M6 launches are more violent and tend to shock the gears alot more than a A4...
--Alan
Old Jul 10, 2006 | 03:22 PM
  #21
Greed4Speed's Avatar
Re: Traction
Gears usually. It'll frag and throw debris all inside the 3rd member and tear things up or throw chunks out. I had a 7.5 in a weak 305 equipped 79 Elky. The ring gear tried to come out of the back cover. Made a nice dent that stuck out 1/4". Luckily it happened while cruising. If it was while accelerating it probably would have pushed through.
Old Jul 10, 2006 | 10:06 PM
  #22
Re: Traction
strength wise 373 are a bit stronger than 410s?
Old Jul 10, 2006 | 10:28 PM
  #23
sandman63's Avatar
Re: Traction
Well if you dont think drag radials are the idea then, what do you recommend? By the way, the tires are garbage, lol. Eagle GT 2's, which are quite old.
Old Jul 10, 2006 | 11:34 PM
  #24
stingercamaro's Avatar
Re: Traction
Two schools of thought:
First: The 3.73 gear sets of fewer teeth so the teeth are thicker/ stronger than the 4.10s
Second: The 4.10s have more teeth so less pressure is exerted on each individual one.
I tend to agree more with the first. Before I really got into fbodys I did a decent of off-roading and almost everyone I talked to, as well as magazines and forum posts I read said the numerically lower you go (higher gears) the more strength you gain. Don't know if the same principles apply on the street but I hope this helps.
Old Jul 11, 2006 | 08:35 AM
  #25
Re: Traction
Well... it's just rebuilt with new parts. New gears, Eaton Posi unit instead of the factory GM limited slip, and a TA cover. Not like it's become bullet proof by any means, but 10 times better than stock.
As far as what I've seen, if you've got a 6 speed and you're running drag radials, you're gonna blow up your 10 bolt. If you've got an auto, then you're going to be good to go for quite some time. Autos just don't subject your drivetrain to the shock that a manual will on the launch, 9 times out of 10.
As far as the times... Don't ask. lol... My local track is the most ghetto POS track in California. I was having traction issues on my friggin ET Streets. -- that should give you an idea of how crappy the track is. I was getting 8.9s in the 1/8th, which is totally unacceptable. I was pulling nicely at the end of the track, to pull in an 87mph trap speed. Add that up. 87mph is no damn 9 second eighth run.
Don't get me wrong, you can still run the drag radials on the street, --lots of people do. I just know I would go nuts driving on them all the time, because I only ride on them to and from the track and I HATE it. It takes some getting used to, the car wanders all over the road and squirms, which requires a lot more constant steering corrections while you're driving. Gets old to me. All that sidewall flex really shines through. I'm a lot happier on my street tires... I can let go of the steering wheel and my car will stay on the road forever, unless the road turns.
If you run the drag radials on the street, you will NEVER lose traction again. Which is good. I love the way my car digs in with the drag radials hot. But you will never pull into the drive thru at McDonalds at the same speed you used to either. I mean, they will make your car handle like sh**. You'll think your 94 Z28 turned into a 77 Monte Carlo when you weren't looking. I honestly can't believe some people are happy driving on drag radials full time.
Some good street tires will hook a stock F-Body up very nicely too, and still handle the right way. The Goodyear F1 GSD3 is a popular tire right now, the BFGoodrich G-Force KD, KDW, all great tires that are also fantastic tires for handling, too. Even my Sumitomo HTRZIIs have been pretty decent at straight line traction, although my 3.73 swap made them protest quite a bit. hehe.
If you wanted to go all out, you could go for the best of both worlds: the Nitto NT-01; my next tire. Soft compound like a drag radial, with a strong sidewall that is good for the road course.
With good street tires like the GSD3, KDW, etc you should be able to set the go pedal to the floor and still hook up. You really will experience a 110% improvement over the tires you're running now. Those old tires you've got on there are the problem.
Old Jul 11, 2006 | 12:17 PM
  #26
sandman63's Avatar
Re: Traction
Thanks Nate, you're the first person to tell me the high's an low's of the mickey ET's, makes my desicion a little harder now tho. Like yeah i wanna just hook up an go, but i dont really think i wanna loose the handling. I dont know, i think those ET's would be alot of fun tho And thanks again.
Old Jul 11, 2006 | 03:07 PM
  #27
Re: Traction
Depending on what size tire you're running, there are several soft compound tires that won't sacrifice handling. The catch is, the stiffer sidewall will ultimately mean more tire shock and less traction off the line.
Old Jul 11, 2006 | 05:31 PM
  #28
RacingTiger04's Avatar
Re: Traction
hmm, i have to chime in now and ask a question myself about this now. if you're running an 18 out back anyway and have a small sidewall, would the drag radial still affect handling THAT badly? im in the same boat as this guy right now, i want a good hooking tire because the 18s are killing my off the line traction, but i LOVE being able to corner hard too =/ until this thread i was all set on ordering some BFG DR's..
Old Jul 12, 2006 | 08:52 AM
  #29
Re: Traction
The fact that you'd be running a 35 (?) series sidewall on the DR would help a little bit. A little... Just due to the fact that there's less sidewall there to begin with. But the problem will still be there; the tires will float around on the sidewall, which is felt in the car as swerving/wandering/squirming as you drive down the street.
DRs are made to have sidewall flexability, that's their purpose -- to give you better straight line traction as they squat down and dig in with a fat, sticky footprint. It's just annoying to me to have to put up with it during day to day driving duties... That's why I'm happy to have two sets of wheels. I only have to put up with it on my way to the dragstrip.
Old Jul 13, 2006 | 04:18 PM
  #30
crb806's Avatar
Re: Traction
i didnt want to make a whole new thread to ask this question so here goes..
how do bfg dr and mt et streets compare in treadlife on the street?
