which tires
which tires
hello iam in the process of getting some new tires for my car, what is a nice tire that is not a drag radial, but has some good performance for the street?and if i do decide to get nittos in the back what tires for the front?i have bfgoodrich drag radials in back now and they just don't seem to last and i do not feel safe in the rain with them.thank you
Re: which tires
i've got kumho 712s just recently
i like them, they seem to stick pretty good, and they'll only start to break loose in the corners if you push it too hard (meaning, you can feel them starting to lose traction rather than at one second you're fine, next, you're in a curb)
they might not be that good for rain, i don't usually drive my z28 in rain if i can avoid it (that's the rs duties right there
87$ on tirerack.com
also, next time, use the wheels and tires forum
just a heads up
)87$ on tirerack.com
just a heads up
Re: which tires
I had ordered some Kuhmo,s 712 but they was on backorder so I cancelled the order. Went to a local tire shop yesterday and they had the Fuzion's great looking tires, hopefully they last as good as they look, plan on ordering some of them tonight from Tirerack.com. The local shop wanted $650 plus tax for a set of 275/40/17's
I called them today and they can mount and balance a set of tires for $15 wheel. So I'm going to order from Tirerack and have them mounting at the tire shop for a total of $560.
