tire inflation pressure question
Old Aug 1, 2008 | 01:40 AM
chya's Avatar
The tires on my z28 state to inflate to 51 psi.
But the door frame states to inflate to 35 psi.
which should I use?
Old Aug 1, 2008 | 03:19 AM
bluz28's Avatar
Lightbulb
51psi is the max tire pressure, myself I run 35psi front and 32psi rear.
Anywhere between 35 - 32 psi front, and 33 - 30psi rear, then just play with the tire psi and see what works best for you.
Old Aug 1, 2008 | 04:22 AM
chya's Avatar
If I run max pressure though, won't I get better tire wear and MPGs?
Are there any dangers that could come from max pressure?
Old Aug 1, 2008 | 04:44 AM
bluz28's Avatar
Lightbulb
IMO,
better mpg , yes!
poor ride quality, yes!
better tire wear, no
uneven tire wear, very possible, yes!
smaller contact patch
Old Aug 1, 2008 | 04:59 AM
chya's Avatar
Ok, thank you.
I don't care too much about the ride because my shocks and everything are all stock. And its a 94 so it really couldn't get much worse. But preserving the tires does matter.
So thank you for the info.
-Justin
Ken Cemo
Jan 27, 2015 08:45 AM
Moshbmx1
Jan 20, 2015 03:27 PM
Jason Short
Jan 19, 2015 06:33 PM
Hurin
Dec 13, 2014 07:38 PM
jp2002ls1
Jul 22, 2002 04:18 PM
