PSI question
Old Apr 17, 2007 | 12:32 PM
Bobsep84's Avatar
PSI question
I have a 95 Camaro Z28 with stock rims...tire size 245-50-16..and was wondering what tire PSI everybody is running for normal street driving. I normally run 30 PSI cold all around because thats what the sticker on the door says...but it seems they are starting to wear more on the outside then the middle. Should i bump up to 32 cold PSI?
Old Apr 17, 2007 | 01:52 PM
87DJP2001's Avatar
32/35 PSI is a good air pressure for the city/highway driving.
Old Apr 17, 2007 | 02:53 PM
Bobsep84's Avatar
Cool, thanks
Old Apr 17, 2007 | 04:17 PM
Capn Pete's Avatar
Yeah, I normally keep mine at ~32 psi. If I'm going to the track, then ~35/36 psi . Seems to work good, and the tire wear has appeared to be even across the tire.
Old Apr 18, 2007 | 09:22 AM
Bobsep84's Avatar
Thats strange how you would use more air when going to the track....one would normally think use less
Old Apr 18, 2007 | 10:42 AM
Capn Pete's Avatar
Misconceptions about "less air = more grip" . Radial tires don't work like old bias-ply or slicks ... often times you need MORE air in them to make them hook . Also, for road racing, you need more air.
Old Apr 18, 2007 | 02:04 PM
Bobsep84's Avatar
Thats very good info to know Im assuming the extra pressure helps keep the bottom of the tire flat on the ground giving you the most contact area?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Deadbolt24
Jan 19, 2015 01:29 PM
jayblev95
Dec 1, 2014 06:55 AM
94_Z28_ragtop
Aug 19, 2002 06:49 PM
