PLEASE help
Old Nov 1, 2007 | 06:06 PM
qudlaty's Avatar
PLEASE help
I've put 17 x 11 with 315 on my car, and the seller gave me some chrome lug nuts. When I put it on it didn't seem tight enough so I tried to tighten it a little more and than took it for a ride and when i came back i wanted to take the wheel off and see if there is any scratches on the tire which would show me that it's rubbing against something. when i tried to take the wheel off i broke one of the pins.
PLEASE tell me it's easy to replace that pin.
How to do it?
__________________
Old Nov 1, 2007 | 06:10 PM
dangalla's Avatar
what is this pin you speak of?
if i am translating correctly you mean wheel stud. right?
front or rear
Old Nov 1, 2007 | 08:59 PM
qudlaty's Avatar
yes stud.
It's done. Wasn't that hard. If only someone told me to release the brake before trying to take the discs of.
Old Nov 1, 2007 | 11:18 PM
n2ceptor's Avatar
You should be using a "bulge nut".... Regular nuts will go in to far and damage the wheel....
Bulge nut..
Regular nut....
See the "taper" end difference.....
Old Nov 2, 2007 | 07:46 AM
shock6906's Avatar
It's not hard to replace a stud. Just go get a new one from Auto Zone or something, knock the old one out with a hammer (you might need a rod to push it through the hub) and then hammer the new one in from the back side of the hub. The studs are not even two dollars each.
