Old Man Needs Fitment Help
Old Mar 30, 2005 | 08:55 PM
85 CAMARO's Avatar
Were planning in running Hoosier Quick time Pro Drag D.O.T. tires on a 3rd Gen with a standard axle and wheel opening. I've been told that the 26x9.5x15" on a 8" rim with 4.5" backspacing is a good fit. Can a 26x11.5x15
on a 10' rim be used without any clearance problems and what would the backspacing be? Thank's for the help. Track opens April 16th.
Old Mar 31, 2005 | 07:47 PM
Stephen 87 IROC's Avatar
Re: Old Man Needs Fitment Help
Should fit but a 5.5" backspacing would be better.
11.5" wide DOT tire is measured across the section width of the tire. Tread width is less.
26 x 9.5 x 15 has a section width of 9.5" on an 8" rim
26 x 11.5 x 15 has a section width of 10.8" on an 8" rim. Putting it on a 10" rim might move the section width out slightly. These are designed for 8-10" rims.
I can't see any clearence problems with either of these tires. They're not tall enough to cause height problems.
I ran MT ET Drag 28 x 9 on a 10" rim with 5.5" backspace that have a section width of 10.8" with no fender modifications at all.
My current 29.5 x 10.5 tires are huge. Total height is 29.9" and the section width is 13.1" but I now have a bunch of inner fender modifications to get them to fit.
Note: Your ISP rejects my mail because my ip is on some blackhole list from a previous ip owner.
marlar98
Oct 21, 2015 02:02 PM
Devinfoote87
Jul 30, 2015 09:54 AM
transamtom
Sep 16, 2002 05:47 AM
206 kaze
3rd Gen / L98 Engine Tech
Sep 8, 2002 11:37 PM
JasonD
Jul 29, 2002 01:46 PM
