NITTO NT 555R & Discount Tire "Heat Cycling"
Old 05-22-2006, 06:00 PM
dutss707's Avatar
Still scrounching around looking for the best setup for my car.
I like the above tires for the rear - 285x35ZRx18. However,
while on DiscountTireDirect.com (I think), there was a process
called "Heat Cycling" for the tires, I read it, but it does not explain
the process...does not give a simple explanation, for a complex mind.
....Please feel free to respond......Thanks
1995 Z28LT1A4: 3:83: Vigilante, 58mmTB, LE2 (by summer), full race
suspension: Red W/ Black Ttop, etc....Too much to list.
dutss707 is offline
Old 05-22-2006, 06:24 PM
2001NBMZ28's Avatar
Re: NITTO NT 555R & Discount Tire "Heat Cycling"
Got a link? I've been running Nitto DRs for years now, both sets from Discount Tire - only warning I ever got was wait a couple days before going to the track cause they put lube on the wheels when mounting them.
2001NBMZ28 is offline
Old 05-23-2006, 01:41 PM
Luke@DTD's Avatar
Thumbs up Re: NITTO NT 555R & Discount Tire "Heat Cycling"
The process for heat cycling is actually very simple. The tire is mounted on a wheel and then set up on rollers that spin the tire. It is heated gradully over a period of time to break down the weaker molicules in the tire and also stretches the tread compound. The benefit of this process is a tread compound that lasts longer and provides better traction.
Hopefully this is helpful information.
If you have any questions, let me know.
Luke- Discount Tire Direct
sfragala@discounttireco.com
Luke@DTD is offline
Jason Short
01-19-2015 06:33 PM
Redbird
08-18-2002 02:48 PM
Redbird
07-31-2002 08:20 PM
MYT30TH
07-28-2002 08:47 AM
Redbird
07-20-2002 06:08 AM
Quick Reply: NITTO NT 555R & Discount Tire "Heat Cycling"
