more tire wear in front or rear?
I just bought some new wheels today that came with tires. Two of the tires are more worn than the other two. So my question is, is it better to put the more worn tires on the front or the rear? Which end will wear faster? Thanks
Re: more tire wear in front or rear?
The general rule is to have more tread on the front for safety, since a majority of your braking is accomplished by your front brakes... And all of your steering.
Put the better tires out front.
actually, you want the better tires on the rear. helps to prevent loss of traction and oversteer in wet situations. if traction is lost on the front, you can detect it and correct in time
michelin themselves did the tests, seen the vids
http://www.discounttire.com/dtcs/infoTiresRear.dos
Was always told the opposite at all the tire shops.Of course throttle steering is my friend
i would say it depends if youre hard on tires or not
If youre gonna be laying down rubber, put the better ones on the rear to even em out. otherwise the fronts typically wear faster.
If youre gonna be laying down rubber, put the better ones on the rear to even em out. otherwise the fronts typically wear faster.oh and vigilante, im jealous of where you live. My grandpa used to live in hill country of Paso Robles/Templeton...I LOVE it up there
So it's agreed that the fronts will wear faster than the rears as long as I don't do a lot of burn outs?
Thanks Zack it is really nice up here. I've been lucky enough to live here my entire life.
no, the rears will wear quicker, especially on our cars
take it from me, i look at about 50 cars a day at work and notice wear patterns
fwd cars fronts are more worn than the rears and vice versa for rwd cars/trucks
Dec 4, 2014 11:56 AM
