lugs for weld prostars
will these work for 95formula 15x8 prostar 5.5bs
grinded calibers, stock stud length for rear?
http://store.summitracing.com/partde...t=WLD-601-1422
or
http://store.summitracing.com/partde...t=WLD-601-1412
or
NHRA requires open-end lug nuts, which is the only difference between the two you listed. If you don't have to pass tech at a track, you could use the 1412. If you have to pass tech 1422.
