finally got my 315's
after searching and searching i finally found a deal on some 17x11 torq thrust IIs, and 315/35/17 goodyear gsc's, check it out.
http://images.cardomain.com/member_i...74_96_full.jpg
Yeah, I have to agree, I mean I like the fatties but the backspacing seems to be a lil off. But hey, if you like 'em, they're GREAT! Everyone's got an opinion, if you like 'em that's the only opinion that matters right? All in all tho,
thumbs up to 315's on an f-body. When I actually get the money and some other projects done, that's my next step is to get some nice tires, and I'm definitely gettin 315s in the back!
The backspacing is way off on those. Are those the 50mm or 56mm backspacing?
I went with the 36.5mm backspacing and my 315s are TUCKED up under the rear. I didn't even have to use the BFH mod. They fit perfectly. I will try and get some pics up tommorow.
Wait, I take that back. NOw that I got a better look at your picture, they look right. You see up until the first water tread line on my 315s.
My bad, 6:00a.m. in the morning and going on 10 hours at work can do that kindd of stuff to you.
same offset as everyone else with an fbod and 315s in the rear, its just the angle, look at these.
this one you can tell it dosnt even stick out:
http://images.cardomain.com/member_i...74_99_full.jpg
guess these cars look rice too..goofs
http://community.webshots.com/photo/...78329992imVZsb
http://bellsouthpwp.net/L/T/LT1ultra...xterior/ss.jpg
both have same offset as me.
