Direct bolt-on?
Old Dec 10, 2005 | 03:10 PM
Resilient94LT1's Avatar
Direct bolt-on?
Would the Z06 wheels in 18x9.5 bolt directly to a 4th gen camaro or would you have to run spacers? Offset +56mm, lug pattern 5x120.65mm. Thanks in advance!
Old Dec 10, 2005 | 04:36 PM
DonMagicalJuan's Avatar
Re: Direct bolt-on?
I have them on my 94Z with 18x9.5's and they fit fine....only problems I encoutered were my tires(295's) in the back were rubbing so I had to take a hammer to the wheel well just a little bit and also on the wheel itself....the center hub on the wheel is just a little bit smaller than the hub on the car, but than can be fixed by sanding the hub on the new wheels to make it a little bigger....Im not sure if its the same size on all the camaros
Old Dec 10, 2005 | 05:27 PM
Re: Direct bolt-on?
Thanks for the info DonMagicalJuan - I would also be running them on a 94Z, except with 275's, if I get them that is. I'm looking at getting a brand new chrome set w/ tires mounted and balanced for around $650 - $700. Just have to see if i can get it to go through..
Old Dec 10, 2005 | 05:28 PM
Re: Direct bolt-on?
Another question... would they look silly at the ride's stock height?
Old Dec 10, 2005 | 06:16 PM
Honda Hunter's Avatar
Re: Direct bolt-on?
Wrong section. The correct section has a great FAQ post that I'm sure can answer your question.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
alliance12364
Sep 17, 2015 08:43 AM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
