changing wheels
Old Sep 23, 2004 | 10:24 AM
enzo1267's Avatar
Question changing wheels
i am going to go from my stock wheels and tires 235-16 to custom painted 10 spoke ss rims with 275's. my question is this with this wheel change will i need to program my pcm or not. i am going to get it programed when i do a gear change but that will not be until next spring.
thanks
Old Sep 23, 2004 | 12:16 PM
Re: changing wheels
The 235/55-16 has an outside diameter of about 26.18" That's what your PCM will have programmed in it. The 275/40-17 has an outside diameter of 25.65". You will have to change the tire diameter in the PCM for the speedo to be correct.
If its just a while 'til you get the programming done, there's not a lot of error. The speedo will be reading about 2% faster than the actual road speed. At a true 70mph its going to be showing 71.4MPH. And when you drive an actual 1,000miles, the odometer will show 1,020 miles.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
Jason Short
Jan 19, 2015 06:33 PM
Collector Car
Jan 5, 2015 10:58 AM
