c5 zo6 wheels
Old Feb 3, 2009 | 04:14 PM
pattracing212's Avatar
c5 zo6 wheels
i'm looking at a set of wheels from oe wheels on ebay and have searched on here but came up empty handed so far. they are 18x10.5 and 17x9.5. the rears have 54mm offset while the fronts have 56mm offset, a little different than the oem zo6 wheels, i just want to know if i will have any issues with rubbing or needing a spacer
Old Feb 4, 2009 | 07:35 AM
GrayZ28's Avatar
I get a little rubbing in the back with my 295s on. Mainly just when i hit a corner really hard. Gonna take the hammer to it and try to roll in the wheel well lip a bit. Normal driving it doesn't rub though. Hope this helps.
Garry
Old Feb 5, 2009 | 03:37 PM
arhey rubbing on the outside of the wheel well?
Old Feb 6, 2009 | 01:21 AM
GrayZ28's Avatar
Yup. On the outside part of the tire wall. Not bad enough to rip chunks of the tire out or anything but some thing that needs to be remedied. The inside lip of the wheel well, you can feel it if you run your fingers over it, just don't slice yourself open, hits the outer wall just enough to cause noise and some abrasion to the tire. Should be a pretty easy fix.
Garry
force10
Aug 10, 2015 08:30 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
