Bogart drag wheels
Old Sep 24, 2005 | 02:47 AM
LT193's Avatar
Bogart drag wheels
Anyone know of any gains at the strip from using such a lightweight wheel?
Old Sep 26, 2005 | 07:31 PM
ABA383's Avatar
Re: Bogart drag wheels
The fronts weigh like 9 lbs, the rears like 10 lbs...Every 100 lb drop in weight is roughly .1 off your ET. Plus the lighter front will help load transfer at launch. The 15" wheel will help by allowing you to run a tire with more sidewall to "wrinkle" and also help your launch....The two drawbacks are high $$$$$$ and they are not designed for street use, and I know some who have cracked fronts on the street...For racing only, they are supposed to be the wheel to use...
--Alan
Old Sep 26, 2005 | 08:32 PM
flatlander757's Avatar
Not to mention it's all rotating weight so it is going to be more effective than removing the same amount of static weight.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BMX Dad
Wheels and Tires
Apr 26, 2015 11:36 PM
Moshbmx1
Jan 20, 2015 03:27 PM
JG94Z
Aug 5, 2002 10:50 PM
