Best slicks?
Ok well I have a rebult tranny with a shift kit so the car is not getting traction in the shifts. I was told best thing to do is get slicks so I will get the track down the track and not end up with burn outs at every shift point down the track.
be careful who you listen to
do not get slicks unless you are prepared to replace your stock rear end. Automatics have a much easier time with them than manual tranny guys, but theres still a chance that the first run you make will send your rear end away in a shower of metal pieces. The rear ends in these cars are notoriously weak under that kind if stress, and upgrading the rear costs anywhere from $1500-$2400 depending on where you go.
You can do it, but like I said, just be ready if/when it happens
why don't you go for a happy medium and get some nitto's? They are a slick composite that is street driveable. Best of both worlds., and not as bad on the rear as full slicks. I ran them on me 160,000 mile rear about 10 times down the track with no problems
All I got are 1/8 mile times but heres a couple times form the last time I ran.
run1 run2 run 3 run4 run5
60ft 2.1898 2.707 2.1799 2.2061 2.2635
330ft 6.00 5.9972 6.025 6.0499 6.0792
1/8 et 9.1590 9.1716 9.2012 9.2095 9.2254
1/8 mph 78.29 77.79 77.77 78.36 78.56
to be blunt your sixty foots suck.... if those are drag radials
what is the #'s on the tire?
what tire pressure do you run?
describe your burnout....
drag radial tires cut 1.6-1.7 sixty foots easily
agreed that a stock/bolt on A4 car cant cut 1.6-1.7 sixties, i was just saying that a drag radial is capable of it or less
from reading this post, i think that he doesnt have DR just nittos.
