92 z28 wheel Question.......
I understand that the only way to use newer bolt pattern wheels is to install an aluminum spacer. I
seem to remember that as you move the wheel centerline further out there is a possiblity of extra stress on the wheel bearings and other parts. This hasn't of course stopped people from doing that.
I also understand if you can shift the wheel/tire inward with an offset wheel that may fix the problem.
My question is does this matter? Has anyone ever used 93-02 roters on an 82-92 camaro? If so is there any modifications like calipers or other parts?
Re: 92 z28 wheel Question.......
I dont know what kind of response you'll get on this board. You might try the 3rd gen board. I think its www.thirdgen.org
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
ChrisFrez
Nov 30, 2014 08:41 AM
