315/35/17's on a 17x9 rim... Who's doing this?
Old Aug 22, 2004 | 07:35 AM
  #16
1stls1's Avatar
Re: 315/35/17's on a 17x9 rim... Who's doing this?
n20blkz, do you have any pics of this, just curious?
Old Aug 22, 2004 | 02:11 PM
  #17
n2oblkz
Guest
Posts: n/a
No, I don't. I'm trying to get set up to post digital pics sometime soon.
Old Sep 25, 2004 | 10:13 AM
  #18
Smokn '94 Z's Avatar
Lightbulb Re: 315/35/17's on a 17x9 rim... Who's doing this?
Well I just orderd a set of 315/35/17 Nittos for my 17x9 ZR1 style rim from Discount Tire. I repeadily ask them if there is any issues I will have from running that size tire on the 9" wide rim and they repeadily told me that the Nitto will not have any problems on it. I said if there is a problem like a lot of knowledgable people on my camaro boards state I might have, then I will want my $$$ back. They said not a problem. As far as me being to worried about how it wears, I don't care cause the car only sees about 500 miles a year anyway. My buddie runs the tire on his '03 Cobra and it looks good....
We'll see I guess...
Old Sep 26, 2004 | 02:04 PM
  #19
Red96Lt1's Avatar
Originally Posted by Spinner
There isnt much of a difference though between the 315s and 275s, about 1/2 of an inch of tread.
Try more like 1.57" difference
Old Sep 26, 2004 | 05:35 PM
  #20
LT4Firehawk's Avatar
It varies from model to model, but there is usually a good 1.5"+ difference in section width (the actual tire width) between a 275/40 on a 9.5" rim and a 315/35 on an 11" rim. Tread width will also vary from model to model, but on the same rims the difference will usually be 1-1.5".
Also, if you are putting a 315 on a 9" rim, remember than the section width will be significantly smaller than the specs on that tire using an 11" wheel. Using the general rule of thumb, there is approximately a .2-.3" reduction in section width for every .5" narrower than the measured rim width (11" for a 315). So, if mounting a 315 on a 9" wheel, you will be reducing the section width by .8-1.2". While the tread width will not be reduced by the same amount due to the design of radial tires, it will be reduced somewhat and may cause improper wear (faster wear in center or sides depending on pressure).
Old Sep 26, 2004 | 05:44 PM
  #21
brain's Avatar
Could be urban legend, but I've always heard that putting a tire that is too big for the wheel will result in the tire bulging in the center, therefore creating LESS contact patch than a properly sized tire on the same rim.
Old Sep 26, 2004 | 06:47 PM
  #22
AutoRoc's Avatar
You can do it but ONLY with a Nitto Drag 315/35/17. They're narrower than any other brand out there. WHY? I have no clue. Any other brand and I would put that size on anything less than 10.5"...11" being the best size.
I can say this because I run this nitto drag 315/35/17 on 17X9.5" ROH Rims and they're definately safe and have a nice look. If I were in your position...and if you're looking for opinions, I'd use a BFG Drag 275/40/17 or the new Mickey Thompson ET radials if they're out now. It'll stick better. Price wise you'd be spending more obviously, goodluck!
WhiteZ95
May 11, 2015 08:52 PM
RUENUF
Aug 26, 2009 10:52 AM
RUENUF
Sep 16, 2002 06:17 AM
RUENUF
Classic Engine Tech
Aug 29, 2002 08:31 AM
RUENUF
Aug 19, 2002 11:30 PM
