285's on 11" wide rim
How will this look, will it be too stretched? I was gonna get 4 315's sumitomo HTRZ but at 156 a piece plus shipping and a 160 treadwear rating I cant afford that this time around so I was looking at 119 a piece kumho 712's in the 285 40 17 size but they are only one half inch wider than the rim....again will that look stupid? I did the 4 17x11 ZR1's for looks and performance so if the 285 doenst look right Ill just have to wait even longer to put them on, already had em 8 months atleast...
Re: 285's on 11" wide rim
are you going to try to put those 11 inch on the front?? if you are im not sure if there going to fit actually i can tell you that they wont without some mods to the suspension the 9.5 inch is cutting it close on my 95 camaro but i was just asking you made it seem like you were.. anyway the 285's will look good i had them on before i switched to my 315's, you can get 315 drag radials from a local discount tire for 136 each i have Sumitomo HTRZ 315's on the rear of mine and 245's in the front there sweet tires really stick when heated.. but heres a pic of my car with the 285's on before i switched to the 315's hope this helps....
http://www.z28.com/attachment.php?at...tid=2341&stc=1
thank you for the pics man! Also yes 11 inch wide rims with 315's do fit up front, a lot of the road racers do that for obvious reasons and use a spacer and a lil notching on the spindle and thats about it, do a search there are tons of pics and info on how to do it, looks pretty sick
Also your link didnt work
You can do it no problem. I've been running that setup for the last yr on 11" wheels all 4 corners. You just need the correct offset to alleviate any rubbing or spacers one or the other. You'll have a slightly higher ride height because of the diamter of the tire but nothing anyone but you will notice. I'm 26" from fender well to the ground so it's low w/ no rubbing issues at all w/ daily driving or road coures. Can view a few pics here.
http://community.webshots.com/album/137726396GwCciw
