18" x 10.5" Y2k rims will they fit my camaro?
okay - got set of rims and tires thinking they were 9.5" off a member and turns out they are 10.5"
im sick right now so cant try installing but what are ur guesses as far as rubbing on a 97 z28... all 4 are 18" x10.5"
Re: 18" x 10.5" Y2k rims will they fit my camaro?
The 2000 C5 wheels show in my reference table from VETTE magazine as 18 x 10.5 with a 58mm offset. That works out to about a 8.0" backspace, which is about 1/10" too much for a 4th Gen. You might be able to get away with some heavy hammering of the inner fender liners, much the way SOME of us with 7.93" backspace ZR1 wheels have done. Depends to some extent on the size tire you put on the wheel.
okay well the tires on them are 275/40 x 18"
that help any- and again these are both for front and back... makes me really nervous
My rear 18x9.5 C5 rear wheels with the standard C5 offset rubbed a bit on the inner fender in the front of each wheel. I had to do a little pounding there to make them work. I'm pretty sure an 18x10.5 would have required a spacer.
To make my problem worse I bought a Moser 9" after getting the Y2k's, the Moser is 1/2" narrower on each side than the 10bolt which didnt help my clearance problem any.
More pounding + spacers fixed that though
damn ... not what i wanted to hear- so this space where would i get one
man this deal i got is really pissing me off- supposed to have been 9.5" on all 4 and dont even get me started on how i got mislead on the tires... trying to get some money back
Originally Posted by GREGG 97Z
Are yours silver painted rims? If so, want to swap a pair of your 18x10.5's for my rear 18x9.5's??? You could run them up front and could keep your tires, they are the correct size for mine. Let me know
i would do it in a heartbeat - but they are chrome....
You may be able to swap them with someone out there though, I'd put a post up in the for sale section, I'd bet someone with Chrome Y2K's would do the trade. Good luck.
thnx again - soon as i get a new tire [ guy really pissed me off ] and get my lugnuts in im gonna try to pursuade my fenderwells a bit and see what happens- if not im sure i could find someone willing for a free upgrade
NewsBot
Jan 8, 2015 11:29 PM
Dec 4, 2014 11:56 AM
