17",18" or both.Z06 wheels question
Old Apr 10, 2004 | 04:56 PM
  #16
1stls1's Avatar
Not only having 17 all the way around helps for rotating,but also the 17" tire is cheaper than the 18:. Just my .02 PS what is the biggest tire on a 17" up front w/out rubbing?
Old Apr 12, 2004 | 09:39 AM
  #17
Greg Nolte's Avatar
The 18" has a deeper inset. Remember inset... I remember when there had to be a couple of inches difference between the front and rear. If you go to the BFG or Nitto web sites they will give you the various dimensions. The only way you can be sure is to get some yard sticks and start measuring. I went with the 18s in the back because the lower shock mount on a 69 goes inside the larger rim but hits on the smaller ones.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Airplanedoc
Feb 1, 2015 07:14 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
ChrisFrez
Nov 30, 2014 08:41 AM
redzed
Sep 4, 2002 06:22 PM
