15in Rims
Old Sep 13, 2006 | 07:10 PM
94 Z KING's Avatar
15in Rims
ok so i thought about gettin some 15 in rims like draglites or something like them. would moving from 16 to 15in. mess my speedo up or anything else??
Old Sep 13, 2006 | 07:38 PM
GMRL's Avatar
Re: 15in Rims
The size of the rim doesnt have anything to do with it.
Its the height of the tire that matters, you want somthing that is the same height or as close as you can to keep the speedo correct.
Heres a good refrence page.
http://www.sstire.com/tireheights.html
Old Sep 13, 2006 | 08:09 PM
The Engineer's Avatar
Re: 15in Rims
With all the PCM programming available, you can easly correct a new tire size, or different gears.
http://www.cardomain.com/ride/2189634
Old Sep 13, 2006 | 09:47 PM
71malibu406's Avatar
Re: 15in Rims
the only thing i'd be worried about is the 15" rims clearing your calipers on the rear or not. not sure about offsets or wheel designs but i do know that the old 15" Vette Rallys i have won't clear the calpers on the rear unless i use a 7/16 spacer. they are 15x7 4.5" BS.
Old Sep 14, 2006 | 02:24 AM
ryan woods's Avatar
Re: 15in Rims
go to the message board scroll down to wheels and tires and then go to wheel and tire faq it should have every thing you need to know!
Old Sep 14, 2006 | 12:48 PM
Re: 15in Rims
Moving to "Wheels and Tires".......
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
