00' Z28 rims on a '95??
Old Apr 28, 2005 | 01:19 PM
rollinn95z's Avatar
Angry 00' Z28 rims on a '95??
Don't know if this has been covered in the past, but I'm swapping my gungy rims out for a set of stocker '00 Z28 rims. As I am unfortunately finding out, there is a lip inside the hub mount of the rim that is not allowing it to fit on the rear axle hubs. They fit fine on the front. Has anybody just ground the lips off without problems?
Thanks.
Old Apr 28, 2005 | 01:22 PM
worak's Avatar
Re: 00' Z28 rims on a '95??
thats what i did two years ago, havent had any problems
Old Apr 28, 2005 | 02:23 PM
sabre81's Avatar
yup, i did also.
Old Apr 28, 2005 | 03:39 PM
Silver's Avatar
me too for '97's on my '95. used a dremel with the steel grinding wheel that looks like a little turbine. tip: keep the dremel moving steadily, don't try to take out a level at a time.
Old Apr 28, 2005 | 09:11 PM
rollinn95z's Avatar
Yeah, I'll give them a run with the Dremel this weekend.
Cheers.
Old Apr 28, 2005 | 09:24 PM
Donny O's Avatar
I did the same with my 01 rims on my 96. well first I forced them on then thought mabye i should jsut remove a little material!!
Old May 10, 2005 | 02:47 AM
superadobo808's Avatar
ditto on the grinding. 97 on a 93
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
